Ir para o conteúdo principal
Lenovo IdeaPad Y580-2099 Keyboard Replacement
O que você precisa
  1. Lenovo IdeaPad Y580-2099 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Y580-2099 Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Lenovo IdeaPad Y580-2099 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Keyboard Replacement: passo 4, imagem 1 %32
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Keyboard Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Y580-2099 Keyboard Replacement: passo 5, imagem 2 %32
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,513
