Introdução
This guide provides instructions on how to replace the daughterboard in the Lenovo IdeaPad Y580-2099 laptop. Removing this part does not require any specialized training or experience as long as the steps are followed closely.
O que você precisa
Use a Phillips #0 screwdriver to remove the 16 screws highlighted. There are 12 M2.5 x 8 mm long screws, and 4 M2 x 2 mm long screws.
Use a Phillips #0 screwdriver to remove the 10 mm screw (highlighted in orange) that secures the disc drive.
Quickly survey and make sure all screws on the back panel are removed from the device.
