Ir para o conteúdo principal
Lenovo IdeaPad Y410p Screen Replacement
O que você precisa
  1. Lenovo IdeaPad Y410p Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Screen Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Y410p Screen Replacement: passo 2, imagem 2 %32
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Screen Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad Y410p Screen Replacement: passo 3, imagem 2 %32
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Screen Replacement, Screen: passo 4, imagem 1 %32 Lenovo IdeaPad Y410p Screen Replacement, Screen: passo 4, imagem 2 %32
    • Using the metal spudger, pry the screen cover off from all sides.
    • Carefully lift the screen cover up and outwards.
    • Place the screen cover aside.
  5. Lenovo IdeaPad Y410p Screen Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Y410p Screen Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad Y410p Screen Replacement: passo 5, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the four 8mm screws from each corner of the screen.
    • Carefully lift the screen up and place it face down on the keyboard.
    • A thick cord connects the bottom of the screen to the computer. Do not tug or remove this cord from the computer.
  6. Lenovo IdeaPad Y410p Screen Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad Y410p Screen Replacement: passo 6, imagem 2 %32
    • Remove the adhesive tape from the small rectangular connector at the bottom of the screen.
    • Carefully pull the wire connector from the screen connector.
    • Remove the screen.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 362
