Introdução
This guide will help you replace the RAM and fix issues like, your laptop running slowly or commonly used apps and functions showing error messages.
O que você precisa
Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
Lift the bottom cover off using a metal spudger and set it aside.
Quase terminado!
Conclusão
