Introdução
Use this guide to remove the CPU of your laptop.
O que você precisa
Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
Unscrew the screws using a Phillips #0 screwdriver.
Unplug the wireless adapter to fully remove the motherboard.
Unscrew the six screws using a Phillips #0 screwdriver.
After you are done unscrewing them, remove the heatsink.
Quase terminado!
Conclusão
