Ir para o conteúdo principal
Lenovo IdeaPad Y400 Battery Replacement
  1. Lenovo IdeaPad Y400 Battery Replacement, Battery: passo 1, imagem 1 %32 Lenovo IdeaPad Y400 Battery Replacement, Battery: passo 1, imagem 2 %32 Lenovo IdeaPad Y400 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
    • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  2. Lenovo IdeaPad Y400 Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Y400 Battery Replacement: passo 2, imagem 2 %32
    • Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out.
    • Slide the second (left) lock to the left and hold it there.
  3. Lenovo IdeaPad Y400 Battery Replacement: passo 3, imagem 1 %32
    • Gently pull the battery out.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 195
