Ir para o conteúdo principal
Lenovo IdeaPad U530 Touch RAM Replacement
O que você precisa
  1. Lenovo IdeaPad U530 Touch RAM Replacement, Battery: passo 1, imagem 1 %32 Lenovo IdeaPad U530 Touch RAM Replacement, Battery: passo 1, imagem 2 %32 Lenovo IdeaPad U530 Touch RAM Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch RAM Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad U530 Touch RAM Replacement: passo 2, imagem 2 %32
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch RAM Replacement: passo 3, imagem 1 %32
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch RAM Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad U530 Touch RAM Replacement: passo 4, imagem 2 %32
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch RAM Replacement: passo 5, imagem 1 %32
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch RAM Replacement: passo 6, imagem 1 %32
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch RAM Replacement, RAM: passo 7, imagem 1 %32 Lenovo IdeaPad U530 Touch RAM Replacement, RAM: passo 7, imagem 2 %32
    • Carefully pull on the tabs on each side of the RAM to release it from its slot
    • Carefully pull the old RAM out of the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 327
