Ir para o conteúdo principal
Lenovo IdeaPad U450 Screen Replacement
O que você precisa
  1. Lenovo IdeaPad U450 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Screen Replacement: passo 2, imagem 1 %32
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Screen Replacement: passo 3, imagem 1 %32
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Screen Replacement: passo 4, imagem 1 %32
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Screen Replacement, Screen: passo 5, imagem 1 %32
    • Open the laptop.
  6. Lenovo IdeaPad U450 Screen Replacement: passo 6, imagem 1 %32
    • Remove the four 7mm phillips head screws in the corners of the screen with a Phillips #00 Screwdriver.
  7. Lenovo IdeaPad U450 Screen Replacement: passo 7, imagem 1 %32
    • Pry the screen out of the tabs with a spudger.
  8. Lenovo IdeaPad U450 Screen Replacement: passo 8, imagem 1 %32
    • Remove the four 7mm phillips head screws located beneath the screen.
  9. Lenovo IdeaPad U450 Screen Replacement: passo 9, imagem 1 %32
    • Pop out the connector that links the screen to the motherboard.
  10. Lenovo IdeaPad U450 Screen Replacement: passo 10, imagem 1 %32
    • Pop the new screen into the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 227
