Ir para o conteúdo principal
Lenovo IdeaPad U430 Touch Wifi Card Replacement
O que você precisa
  1. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 3, imagem 2 %32
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Wifi Card: passo 4, imagem 1 %32
    • Remove the two 2.8mm screws using the Phillips #0 screwdriver.
  4. Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 5, imagem 2 %32
    • Remove the two snap cables connecting the wifi card to the rest of the computer.
  5. Lenovo IdeaPad U430 Touch Wifi Card Replacement: passo 6, imagem 1 %32
    • Slide the Wifi card away from the Wifi card connector.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 606
