Ir para o conteúdo principal
Lenovo IdeaPad U430 Touch Trackpad Replacement
O que você precisa
  1. Lenovo IdeaPad U430 Touch Trackpad Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Trackpad Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad U430 Touch Trackpad Replacement: passo 3, imagem 2 %32
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Trackpad Replacement, Battery: passo 4, imagem 1 %32 Lenovo IdeaPad U430 Touch Trackpad Replacement, Battery: passo 4, imagem 2 %32
    • Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
  4. Lenovo IdeaPad U430 Touch Trackpad Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad U430 Touch Trackpad Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
    • When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
    • The battery connector is very tight fitting, you may need to use a metal spudger in order to get the connector out far enough.
  5. Lenovo IdeaPad U430 Touch Trackpad Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad U430 Touch Trackpad Replacement: passo 6, imagem 2 %32
    • Once the battery is disconnected, lift up on the front of the battery and remove it from the laptop body.
  6. Lenovo IdeaPad U430 Touch Trackpad Replacement, Trackpad: passo 7, imagem 1 %32 Lenovo IdeaPad U430 Touch Trackpad Replacement, Trackpad: passo 7, imagem 2 %32
    • Remove the two 2.8 mm screws attached to the trackpad using the Phillips #1 screwdriver.
    • Detach the zif ribbon labeled "TP" and "MB" at the "MB" end.
  7. Lenovo IdeaPad U430 Touch Trackpad Replacement: passo 8, imagem 1 %32
    • Grasping one of the screw brackets, gently lift the trackpad out of its frame.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 310
