Introdução
Use this guide to replace a bad motherboard on your Lenovo Ideapad U430 touch.
O que você precisa
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
Using a plastic spudger, liift up and remove the hard drive and screen flat-topped connectors
Use the spudger and metal tweezers to remove the two cable connectors and two bundled cable connectors.
Use the plastic spudger to lift up and remove the two antenna connectors.
3 outras pessoas executaram este guia.
