Ir para o conteúdo principal
Lenovo IdeaPad U430 Touch Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Hard Drive Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad U430 Touch Hard Drive Replacement: passo 3, imagem 2 %32
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Unplug the hard drive from the 22-pin cable (LZ9 HDD cable).
    • At the time of guide creation, the device did not come equipped with the hard drive.
  4. Lenovo IdeaPad U430 Touch Hard Drive Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool, lift the hard drive from its compartment.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
1. Of the first 10 screws, you did not mention that 2 of them are longer.
2. You can't lift the hard drive out without removing 4 screws (one at each corner of the drive). The plastic tool is not needed for this.
Todd McQueen - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Ao todo: 1,741
