Ir para o conteúdo principal
Lenovo IdeaPad U430 Touch Bottom Cover Removal
O que você precisa
  1. Lenovo IdeaPad U430 Touch Bottom Cover Removal, Bottom Cover: passo 1, imagem 1 %32
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Bottom Cover Removal: passo 3, imagem 1 %32 Lenovo IdeaPad U430 Touch Bottom Cover Removal: passo 3, imagem 2 %32
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Conclusão
Patrick Ripkey
Membro desde: 02/28/17
627 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G6, Nance Spring 2017 Membro de USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
Membros da 3
Autoria de 15 guias
Um comentário
When removing the cover, be careful: There are a few (two or three?) plastic hooks that break easily in the area around the ports and the SD slot. (It's no big deal if they do break, but you can avoid it.)
Tom Janson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 2,957
