Ir para o conteúdo principal
Lenovo IdeaPad U410 Screen Replacement
O que você precisa
  1. Lenovo IdeaPad U410 Screen Replacement, Screen: passo 1, imagem 1 %32 Lenovo IdeaPad U410 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Make sure your laptop is turned off before disassembling.
    • Power off the laptop.
    • Using the metal spudger, gently pry off the black trim around the screen.
    • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
  2. Lenovo IdeaPad U410 Screen Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad U410 Screen Replacement: passo 2, imagem 2 %32
    • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
    • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
  3. Lenovo IdeaPad U410 Screen Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad U410 Screen Replacement: passo 3, imagem 2 %32 Lenovo IdeaPad U410 Screen Replacement: passo 3, imagem 3 %32
    • Lower LCD screen onto the keyboard.
    • Find the gold connector on the bottom of the LCD panel.
    • Gently grab the connector on both sides and pull the connector straight out.
    • Connector cable is very fragile. Use the least amount of force possible.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 1,481
