Introdução
This screen replacement guide will show you how to replace your defective LCD screen on your Lenovo U410. You will need a Phillips #1 screwdriver and a metal spudger. Be careful when removing the plastic trim and connectors because you can easily break them.
O que você precisa
Power off the laptop.
Using the metal spudger, gently pry off the black trim around the screen.
Uma outra pessoa concluiu este guia.
