Ir para o conteúdo principal
Lenovo IdeaPad U410 Battery Replacement
O que você precisa
  1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad U410 Battery Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad U410 Battery Replacement: passo 2, imagem 3 %32
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Battery Replacement, Battery: passo 3, imagem 1 %32
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Lenovo IdeaPad U410 Battery Replacement: passo 4, imagem 1 %32
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Lenovo IdeaPad U410 Battery Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad U410 Battery Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad U410 Battery Replacement: passo 5, imagem 3 %32
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 848
