Ir para o conteúdo principal
Lenovo IdeaPad U350 RAM Replacement
O que você precisa
  1. Lenovo IdeaPad U350 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are 4.7mm long with a head diameter of 3.68mm.
    • The screws are attached to the panel. When unscrewing be sure to stop when you hear a click.
  2. Lenovo IdeaPad U350 RAM Replacement: passo 2, imagem 1 %32
    • Gently lift the back panel from the side closest to the battery and remove panel
  3. Lenovo IdeaPad U350 RAM Replacement: passo 3, imagem 1 %32
    • Push retention clips outward and then gently slide out of slot
  4. Lenovo IdeaPad U350 RAM Replacement: passo 4, imagem 1 %32
    • Remove white and black wires to make room to remove the second RAM module.
  5. Lenovo IdeaPad U350 RAM Replacement: passo 5, imagem 1 %32
    • Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • When re-installing RAM modules, be sure to insert them at a 45 degree angle. This is the same angle that they should pop up to after the retention clips are pushed outward.
Conclusão
James Morizzo
Membro desde: 09/29/14
496 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-4, Hickman Fall 2014 Membro de USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 985
