Ir para o conteúdo principal
Lenovo IdeaPad U350 Keyboard Replacement
O que você precisa
  1. Lenovo IdeaPad U350 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery by turning the laptop over.
  2. Lenovo IdeaPad U350 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad U350 Keyboard Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad U350 Keyboard Replacement: passo 2, imagem 3 %32
    • Locate the lock switch and slide toward the outside edge of the laptop until it clicks into place and the battery unit pops up.
    • Remove the battery unit from the laptop and set it aside.
  3. Lenovo IdeaPad U350 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Unscrew the three screws on the bottom of the laptop that have small keyboard logos next to them using a PH1 screwdriver. These screws are 5.8mm long.
  4. Lenovo IdeaPad U350 Keyboard Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad U350 Keyboard Replacement: passo 4, imagem 2 %32
    • Flip the computer over and open the screen.
    • Use a spudger to carefully press in the clip that is found here while prying the keyboard upward from the same side.
    • This clip is very stiff and also made of thin, brittle plastic. This means that it is easy to break off, which is what we did during our disassembly.
  5. Lenovo IdeaPad U350 Keyboard Replacement: passo 5, imagem 1 %32
    • Slightly lift the bottom of the keyboard towards the screen to locate the keyboard's ribbon cable.
    • Use the tip of the spudger to lift the black retaining flap on the ZIF connector.
    • You should now be able to lift out the keyboard easily.
Conclusão
Uma outra pessoa concluiu este guia.
Jason Sweeney
Membro desde: 09/22/14
825 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-4, Hickman Fall 2014 Membro de USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 1,749
