Ir para o conteúdo principal
Lenovo IdeaPad U310 Ram Replacement
O que você precisa
  1. Lenovo IdeaPad U310 Ram  Replacement, RAM: passo 1, imagem 1 %32
    • Make sure device is turned off and disconnected from any power source before proceeding.
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Ram  Replacement: passo 2, imagem 1 %32
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Ram  Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad U310 Ram  Replacement: passo 3, imagem 2 %32
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Ram  Replacement: passo 4, imagem 1 %32
    • Pry the RAM's two holding clips in an outward motion.
  5. Lenovo IdeaPad U310 Ram  Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad U310 Ram  Replacement: passo 5, imagem 2 %32
    • Continue to pry open the clips, and slip the RAM from its housing.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 2,485
