Ir para o conteúdo principal
Lenovo IdeaPad S400 Touch Speakers Replacement
O que você precisa
  1. Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: passo 1, imagem 1 %32 Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: passo 1, imagem 2 %32 Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: passo 1, imagem 3 %32
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: passo 2, imagem 1 %32 Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: passo 2, imagem 2 %32 Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: passo 2, imagem 3 %32
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch Speakers Replacement: passo 3, imagem 1 %32
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch Speakers Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad S400 Touch Speakers Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad S400 Touch Speakers Replacement: passo 4, imagem 3 %32
    • Remove the two 2mm Phillips #0 screws from each speaker.
    • Take the speakers off the base.
    • Pull the connecting cable from the motherboard, which will release the speakers.
    • To install the replacement speakers, follow these steps in reverse order.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 168
