Ir para o conteúdo principal
Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
O que você precisa
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 2, imagem 1 %32
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 1 %32 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 2 %32
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
82.281 Reputação
Autoria de 200 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.298 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 44
Duração total: 1,042
