O que você precisa
Power off the laptop and place it face-down on a non-scratching surface.
Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
Remove the two 3 mm screws connecting the fan to the casing using a Phillips #0 screwdriver.
Carefully unwind the black cable that runs between the top of the battery and the bottom of the fan from the grooves along the side of the fan.
In order to do so, you will need to pull up the metallic tape that holds the cable in place using either your fingers or a plastic prying tool to lift up the edge.
Remove the three 3 mm screws that secure the black heat sink near the top of the computer using a Phillips #0 screwdriver.
Lift the heat sink vertically to remove it from the laptop.
Uma outra pessoa concluiu este guia.
