Ir para o conteúdo principal
Lenovo IdeaPad S340-15IWL Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Remove the four 3 mm screws holding the hard drive expansion slot in place using a Phillips #0 screwdriver.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
92.249 Reputação
Autoria de 241 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.527 guias
Um comentário
I managed to take the case apart once, but when I tried to put back the Torx screws back in, I noticed one wouldn't go more than halfway -- it then turned freely. I'd ordered an SSD thinking that it would be a simple matter to install it, but I found that half the Torx screws wouldn't come out, even using a tiny screwdriver to try to prise them out while turning the Torx wrench. They're seated in brass sleeves -- no way I stripped those out; the sleeves must be glued into the plastic of the case and the glue given out. There now seems to be no way to take the case apart without destroying it completely.
Robert - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 97
Ao todo: 3,059
