Ir para o conteúdo principal
Lenovo IdeaPad S340-15IWL CMOS Battery Replacement
O que você precisa
  1. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: passo 2, imagem 1 %32
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: passo 3, imagem 1 %32 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: passo 3, imagem 2 %32 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: passo 3, imagem 3 %32
    • Remove the circular CMOS battery on the far left side of the computer by lifting it with your finger or an opening tool.
    • This is only attached with adhesive, so it does not require extensive force.
  4. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: passo 4, imagem 2 %32
    • Unplug the bundled red and black wires connecting the CMOS battery to the side of the device.
    • Remove the CMOS battery from the laptop.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
82.675 Reputação
Autoria de 202 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.419 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 49
Últimos 30 dias: 152
Duração total: 1,678
