Ir para o conteúdo principal
Lenovo IdeaPad S340-15IWL Battery Replacement
O que você precisa
  1. Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Battery Replacement: passo 2, imagem 1 %32
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: passo 3, imagem 1 %32 Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
Conclusão
Um comentário
Worked wonderfully. Thanks for the great instructions.
Deb Dhar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 37
Últimos 30 dias: 128
Duração total: 5,418
