Introdução
This guide will explain how to replace your System Memory (also known as RAM). Faulty RAM modules may cause reduced system stability and performance.
O que você precisa
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
Release the RAM from the motherboard by pressing the two locking latches away from each other.
Quase terminado!
Conclusão
