Ir para o conteúdo principal
Lenovo IdeaPad S210 Touch System Memory / RAM Replacement
O que você precisa
  1. Lenovo IdeaPad S210 Touch System Memory / RAM Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 2, imagem 2 %32
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch System Memory / RAM Replacement, Back Panel: passo 3, imagem 1 %32 Lenovo IdeaPad S210 Touch System Memory / RAM Replacement, Back Panel: passo 3, imagem 2 %32
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 4, imagem 1 %32
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 5, imagem 3 %32
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch System Memory / RAM Replacement, System Memory / RAM: passo 6, imagem 1 %32 Lenovo IdeaPad S210 Touch System Memory / RAM Replacement, System Memory / RAM: passo 6, imagem 2 %32
    • Release the RAM from the motherboard by pressing the two locking latches away from each other.
  7. Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 7, imagem 2 %32 Lenovo IdeaPad S210 Touch System Memory / RAM Replacement: passo 7, imagem 3 %32
    • After the latches are unlocked, the RAM module will shift so it sits at an angle. Gently pull RAM module at this angle to free it from the socket.
    • When reinstalling, be sure to align the notch on the RAM stick with the slot on your motherboard. Improper installation may cause damage to the motherboard or RAM.
Conclusão
Zack Colman
Membro desde: 07/08/19
885 Reputação
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 678
