Ir para o conteúdo principal
Lenovo IdeaPad S210 Touch Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 2, imagem 2 %32
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: passo 3, imagem 1 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: passo 3, imagem 2 %32
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 4, imagem 1 %32
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 5, imagem 3 %32
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32
    • Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
  7. Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 7, imagem 2 %32
    • Slide your hard drive away from your motherboard until fully removed.
    • Be careful not to snag any wires routed along the battery side of the hard drive.
  8. Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 8, imagem 2 %32 Lenovo IdeaPad S210 Touch Hard Drive Replacement: passo 8, imagem 3 %32
    • This step is only necessary if you are swapping your old hard drive for a new one.
    • Using a Phillips #0 screwdriver, remove four 2.5mm screws, two per side, to release the hard drive from its mounting bracket. These screws are directly next to each mounting screw you removed previously.
    • Install the mounting brackets onto the new hard drive during reassembly.
Conclusão
Zack Colman
Membro desde: 07/08/19
906 Reputação
Autoria de 8 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 15
Ao todo: 1,501
