Ir para o conteúdo principal
Lenovo IdeaPad S210 Touch Back Panel Replacement
O que você precisa
  1. Lenovo IdeaPad S210 Touch Back Panel Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Back Panel Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad S210 Touch Back Panel Replacement: passo 2, imagem 2 %32
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: passo 3, imagem 1 %32 Lenovo IdeaPad S210 Touch Back Panel Replacement, Back Panel: passo 3, imagem 2 %32
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Back Panel Replacement: passo 4, imagem 1 %32
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Back Panel Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad S210 Touch Back Panel Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad S210 Touch Back Panel Replacement: passo 5, imagem 3 %32
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
Conclusão
Zack Colman
Membro desde: 07/08/19
885 Reputação
Autoria de 8 guias
Um comentário
Witam ile zatok część chce pan
Mikolaj Dabrowski - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 556
