Ir para o conteúdo principal
Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement
O que você precisa
  1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement, Wireless WiFi Card: passo 1, imagem 1 %32
    • The tools needed are the blunt edge of the spudger and a Phillips J0 head screwdriver.
    • Ensure your device is powered off before continuing.
  2. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 2, imagem 2 %32
    • Turn the laptop over to begin.
    • Remove the two 40 mm screws with a Phillips J0 head screwdriver.
  3. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 3, imagem 2 %32
    • The WiFi card is found near the bottom of the panel.
  4. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 4, imagem 3 %32
    • Do not use the metal precision tweezers as shown.
    • Using the blunt end of the spudger, wedge the spudger beneath the connector and pull straight up to remove the white wire. Repeat to remove the black connector.
    • When reinstalling these U.FL connectors, hold the connector in place and gently push down. The connector should snap into place like a button.
  5. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: passo 5, imagem 3 %32
    • Remove the two 40 mm screws using a Phillips J0 head screwdriver.
    • Lift and remove the WiFi card.
Conclusão
Uma outra pessoa concluiu este guia.
Lucy Mendez
Membro desde: 10/10/15
152 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 2,102
