Ir para o conteúdo principal
Lenovo IdeaPad S10-2 Hard Drive Replacement
O que você precisa
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 4, imagem 2 %32
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 5, imagem 2 %32
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 6, imagem 2 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 6, imagem 3 %32
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad S10-2 Hard Drive Replacement: passo 7, imagem 2 %32
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
Conclusão
Anthony
Membro desde: 10/13/15
258 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 9,500
