Pular para o conteúdo principal
Introdução
Can't watch movies? Change your optical drive with this guide!
Peças
Nenhum componente especificado.
  1. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Now push the right clip to the right and hold it while using your other hand to pull the battery out. Now push the right clip to the right and hold it while using your other hand to pull the battery out.
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove the two screws highlighted.
    • Remove the two screws highlighted.
  5. This is the back of the laptop with the cover removed.
    • This is the back of the laptop with the cover removed.
  6. Locate and remove the single screw right of the optical drive
    • Locate and remove the single screw right of the optical drive
  7. Optical Drive should slide out easily with one thumb's effort.
    • Optical Drive should slide out easily with one thumb's effort.
Conclusão
Christopher
Membro desde: 08-04-2014
666 reputação
6 Guias de autoria
Equipe
Cal Poly, Team 8-7, Regan Spring 2014 Membro de Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Membros
10 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 284
