Ir para o conteúdo principal
Lenovo IdeaPad N586 Keyboard Replacement
O que você precisa
  1. Lenovo IdeaPad N586 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  2. Lenovo IdeaPad N586 Keyboard Replacement: passo 2, imagem 1 %32
    • Slowly and gently lift the keyboard up to separate from the chassis.
  3. Lenovo IdeaPad N586 Keyboard Replacement: passo 3, imagem 1 %32
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  4. Lenovo IdeaPad N586 Keyboard Replacement: passo 4, imagem 1 %32
    • Now remove the keyboard from the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher
Membro desde: 04/08/14
676 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-7, Regan Spring 2014 Membro de Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
Membros da 5
Autoria de 10 guias
Um comentário
WARNING!!!!!!
These steps do not include removing the three screws that secure the keyboard to the bottom of the latop!!! They are marked with tiny keyboard icons. One is under the bottom panel, so that has to be removed first.
Clint Hatchett - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,827
