Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  2. Slowly and gently lift the keyboard up to separate from the chassis.
    • Slowly and gently lift the keyboard up to separate from the chassis.
  3. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Gently lift the keyboard off the chassis.
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  5. Now remove the keyboard from the computer.
    • Now remove the keyboard from the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher
Membro desde: 08-04-2014
666 reputação
6 Guias de autoria
Equipe
Cal Poly, Team 8-7, Regan Spring 2014 Membro de Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Membros
10 Guias de autoria
WARNING!!!!!!
These steps do not include removing the three screws that secure the keyboard to the bottom of the latop!!! They are marked with tiny keyboard icons. One is under the bottom panel, so that has to be removed first.
Clint Hatchett - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Todo: 1,554
