Introdução
If your RAM is insufficient or failing, you may want to replace or upgrade it by following this guide.
O que você precisa
Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
Rotate the laptop so that now the hinge is facing away from you.
Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
Uma outra pessoa concluiu este guia.
