Introdução
If your device is completely unresponsive or continuously freezes as you work, the CPU may be the issue. To replace this part, follow this guide.
O que você precisa
Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
Rotate the laptop so that now the hinge is facing away from you.
Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
Slide the bottom panel towards you until it stops, and then carefully lift it off.
Remove the five ribbon cables on the top of the computer.
Gently remove the single cable from its socket.
5 outras pessoas executaram este guia.
Um comentário
süper olmuş eline sağlık çok açıklayıcı ve başarılı olmuş teşekkür ederim
