Ir para o conteúdo principal
Lenovo IdeaPad G50-45 Screen Replacement
O que você precisa
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: passo 2, imagem 1 %32
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad G50-45 Screen Replacement: passo 3, imagem 2 %32 Lenovo IdeaPad G50-45 Screen Replacement: passo 3, imagem 3 %32
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: passo 4, imagem 1 %32
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: passo 5, imagem 1 %32
    • Test the new screen by turning it on before putting the bezel back on.
Conclusão
6 outras pessoas executaram este guia.
Jessy McDermott
Membro desde: 10/26/15
200 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membro de UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Membros
5 Guias de autoria
2 comentários
The tutorial was pretty straightforward, and worked.
Remy G - Responder
My Laptop is got work the searen is blue it what trun on
Rebecca - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Duração total: 7,574
