Ir para o conteúdo principal
Lenovo IdeaPad G50-45 Fan Replacement
O que você precisa
  1. Lenovo IdeaPad G50-45 Fan Replacement, Fan: passo 1, imagem 1 %32
    • Safely flip the device upside down and use the Phillips head screwdriver to remove the 3 screws at the bottom of the device which are circled.
  2. Lenovo IdeaPad G50-45 Fan Replacement: passo 2, imagem 1 %32
    • Slide, do not lift, the bottom panel off once the 3 screws are off.
  3. Lenovo IdeaPad G50-45 Fan Replacement: passo 3, imagem 1 %32
    • Locate the fan in the upper right corner above the orange bar and appears as a silver semicircle.
  4. Lenovo IdeaPad G50-45 Fan Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad G50-45 Fan Replacement: passo 4, imagem 2 %32
    • Remove the 3 screws attaching the fan to the device.
  5. Lenovo IdeaPad G50-45 Fan Replacement: passo 5, imagem 1 %32
    • Once the screws are removed slowly lift the fan out, there will be a thin wire connected to the device and fan still, Firmly grasp the white end of the wire where the wire splits into 2 and pull it out.
  6. Lenovo IdeaPad G50-45 Fan Replacement: passo 6, imagem 1 %32
    • The fan should be removed now and appear as so.
Conclusão
3 outras pessoas executaram este guia.
Robert Muir
Membro desde: 10/26/15
359 Reputação
2 Guias de autoria
Equipe
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membro de UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Membros
5 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 2,822
