Ir para o conteúdo principal
Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement, Base Cover: passo 1, imagem 1 %32
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 2 %32
    • Detach the gray and black wires from the Wi-Fi card.
  4. Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Remove the single 3.5 mm screw that secures the Wi-Fi card using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 6-14IKB Wi-Fi Card Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the Wi-Fi card from its slot using tweezers.
    • When reinstalling, the gray wire goes into the connector labeled number 1. The black wire goes into the connector labeled number 2. You will hear an audible click when it is properly clipped back into place.
Conclusão
Um comentário
Where can I buy the chip?
Clarissa Whitaker - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 386
