Introdução
This guide will walk you through the steps of removing the SSD card. The SSD card is essential to the Lenovo IdeaPad Flex 6-14IKB because it allows for the laptop to obtain storage and the memory of the device.
O que você precisa
Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
Remove the single 3.5 mm screw that secures the SSD card using a Phillips #00 screwdriver.
3 outras pessoas executaram este guia.
