Ir para o conteúdo principal
Lenovo IdeaPad Flex 5-1570 Speaker Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 3, imagem 2 %32
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  5. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 5, imagem 2 %32
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  6. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: passo 6, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: passo 6, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 7, imagem 2 %32
    • Using your hands, gently pull the left speaker up and out of the device.
  8. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: passo 8, imagem 2 %32
    • Repeat the previous step for the other speaker and remove the speakers from the device.
Conclusão
Nate Blake
Membro desde: 01/23/20
507 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S2-G6, White Winter 2020 Membro de Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 501
