Introdução
Almost everything that may need replacing in your Lenovo IdeaPad Flex 5-1570 can be found underneath the back panel. A damaged back panel is problematic on its own but can also lead to other more serious problems if not replaced. Removing the back panel is a little tricky, however following the steps in this guide should allow for a smooth removal.
O que você precisa
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
Uma outra pessoa concluiu este guia.
