Ir para o conteúdo principal
Lenovo IdeaPad Flex 5-1470 Motherboard Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, SSD: passo 3, imagem 1 %32
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
  4. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  5. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: passo 5, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  6. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: passo 6, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 24
Duração total: 403
