Introdução
Is the display to your Lenovo IdeaPad Flex 5 14ARE05 giving you problems? In this guide, you will find a step-by-step guide on how to replace it. The display allows you to interact with your laptop. When it malfunctions you may have problems with a flashing screen, or an unstable picture preventing you from using your laptop effectively. Before starting this guide make sure to power down the laptop and disconnect it from any power sources.
O que você precisa
Remove the five 8 mm screws using a T5 Torx Screwdriver.
Remove the four 5 mm screws using a T5 Torx Screwdriver.
Remove the four 2 mm screws using a JIS #1 screwdriver.
Remove the three 5 mm screws using a JIS #1 screwdriver.
