Ir para o conteúdo principal
Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: passo 1, imagem 1 %32
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 2, imagem 2 %32
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 4, imagem 1 %32
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 5, imagem 1 %32
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: passo 6, imagem 1 %32
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 7, imagem 2 %32
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: passo 8, imagem 1 %32
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
Conclusão
Elijah Ellis
Membro desde: 11/08/18
616 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
Membros da 3
Autoria de 5 guias
2 comentários
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - Responder
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,221
