Ir para o conteúdo principal
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: passo 1, imagem 1 %32
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 2, imagem 2 %32
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 5, imagem 2 %32
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: passo 6, imagem 1 %32
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 8, imagem 1 %32
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
Conclusão
Elijah Ellis
Membro desde: 11/08/18
616 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 1,303
