Ir para o conteúdo principal
Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: passo 1, imagem 1 %32
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 2, imagem 2 %32
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 5, imagem 2 %32
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Demario Robinson
Membro desde: 10/02/17
1.038 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G6, Thompson Fall 2017 Membro de USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
Membros da 3
Autoria de 10 guias
Um comentário
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 1,653
