Ir para o conteúdo principal
Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: passo 1, imagem 1 %32
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 2, imagem 2 %32
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: passo 3, imagem 1 %32
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 4, imagem 1 %32
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 5, imagem 2 %32
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: passo 6, imagem 1 %32
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
Conclusão
Elijah Ellis
Membro desde: 11/08/18
616 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
Membros da 3
Autoria de 5 guias
Um comentário
Does this procedure reset the BIOS?
Mark Webb - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 2,611
