Ir para o conteúdo principal
Lenovo IdeaPad Flex 4-1470 Battery Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: passo 1, imagem 1 %32
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 2, imagem 2 %32
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 4, imagem 1 %32
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery up and out of the laptop.
Conclusão
9 outras pessoas executaram este guia.
Demario Robinson
Membro desde: 10/02/17
1.038 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G6, Thompson Fall 2017 Membro de USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
Membros da 3
Autoria de 10 guias
2 comentários
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - Responder
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 13,939
