Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
Remove the connector attaching the battery to the motherboard.
Lift up black flap on the ZIF connector and pull the ribbon cable out.
Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
Remove one last connector cable.
Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
Lift up the black tab on the ZIF connector and pull the ribbon cable out.
